not enough vacuum
Old Jul 12, 2005 | 09:54 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
not enough vacuum
hi,
i have my pcv and brakebooster with a t-fitting at the back of my double pumper. but the brakes dont get enough vacuum to operate properly. when i remove the pcv it works good.
how can i fix this? pcv is new. normally i would connect the brakes to the manifold, but i dont have enough room because of the carb.
nebu.
Old Jul 12, 2005 | 11:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'll either have to move the carb up via a spacer, or find a way to get a fitting under the fuel bowl to the manifold.
This is exactly why many of us say not to T the PCV and brake booster together.
Old Jul 12, 2005 | 04:00 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
i cant put a spacer on because i have no room left between the aircleaner and the hood and there is appr. 0.3" between the fuel bowl and manifold. i dont think there is 90° a fitting this small available.
is it possible to hook the pcv to the timed vacuum port?
Nebu.
Old Jul 13, 2005 | 12:21 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
If you have an Edelbrock intake these will help you.
Edelbrock Low-Profile Vacuum Fitting EDL-8096 9.95
Summit Straight Fittings 3/8 NPT to 3/8 Rubber Hose SUM-G3116 5.95
These are what I used I connect my brakes to this and the PCV to the carburetor.
Old Jul 13, 2005 | 06:18 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I had the same problem. My cam is so radical it would not build up enough vaccum. I used one of those comp cams resovoirs and it works awsome.
Old Jul 13, 2005 | 09:46 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
This is on a FWD GMC motorhome but you will get the idea. It is a GM electric vacuum pump that is used to boost vacuum to the power brakes. The 1992 donor van that I used had one under the battery box of all places. I relocated it under the evaporator box on my 1983. My power brakes work great. Alot better than they ever did off engine vacuum alone.
http://www.gmcmotorhome.com/tech/vacuum_pump/index.html
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
