need help w/ holly carb
Car: 88 Camaro
Engine: 406
Transmission: th350
well i just got a new 750 CFM holley w/ vacuum secondaries. it has about 30 mins of run time from the guy i bought it off of. basically brand new. well here's the problem.. it idles great but as soon as u try to take it off idle it starts sputterin out and fallin on its face..i adjusted the floats correctly (when i take the screw out the gas is just to the bottom of the hole and just barely trickles out) i'll do this and it runs great for about 5-10 minutes and then starts doing the same thing again. i'll mess with the float levels and then re adjust it and it will run perfect for about 5-10 more minutes and start doing the same thing again.. also when its acting up if i put it at half throttle it will rev up and start surging like its running out of gas. the fuel pump is brand new and there is no problems with the fuel system.. what could be causing this?? sticky floats or what?
thanks!
thanks!
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
sounds like a fuel starvation problem.
Look for a crimped line or clogged filter.
Also remove the filters in the float bowls. They may be clogged.
Transmission: 4L80E/4L80E
But put filters back in before you run it again. You are also supposed to have another filter (in-line) before the carb.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
30 minutes of run time...how long ago? If it has'nt sat for too long nothing "should be" varnished up internally, but ya never know.
Sounds like possible contamination of the needle and seat with crap/crud allowing fuel past when it should be holding it back. If you done have pre carb filter installed, do so immediately before continuing or you may have a crispy critter for a car....been there done that in HS
Are you running the right size power valve up front? They come stock with a 6.5" PV. Let the car warm upto temp at an idle, then have a buddy put the car in gear. Take a manifold vacuum reading and then divide that number in half...that is the size PV you should be running. Ex. 10" of vacuum you need a 4.5 or 5.5" PV, easier to get it on the small side. 6" of vacuum run a 3.5" or 2.5" PV, so on and so forth
Do you have the idle mixture screws adjusted properly. Just to do a double check, turn the screws all the way in until they just seat, then back them out 1 1/2 turns, this is the oout of box setting for Holley carbs and will get you close to where you need to be.
How much clearance do you hve in the front accelertor pump. Youo should be able to get a .015 feeler gauge between the arm and spring without squirting gas.
Car: 88 Camaro
Engine: 406
Transmission: th350
thanks for the help. i took the float bowls out and it was N-A-S-T-Y inside..cleaned it all out and now it works great! im gonna do the vacuum test for the power valve tomorrow..once again thanks for all the help
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
