EFI to Carb swap question
Old Jul 26, 2005 | 01:48 PM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
I did a quick search and did not find much. '88 formula 350 thinking of swapping to carb. This is what i can think of as far as parts:
Early f- car distributor
return style fuel pressure regulator for dialing down electric pump
intake
carb
Fuel filter
Fuel lines
Vacuum Lines
Anyone think of anything i'm missing. Thanks.
Old Jul 26, 2005 | 03:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Early f-body distributor? Why do you say that? All you need is an HEI unit with vacuum/mechanical advance.
You'll need various coolant hoses, different throttle/cruise cables, gaskets, air cleaner.
Old Jul 26, 2005 | 08:45 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Only other thing that i can think of is a throttle return spring and you'll want to run a fuel pressure gauge.
Why are you swapping to Carb? It may be a good time to change the cam also
Old Jul 30, 2005 | 10:56 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
i guess my mini write-up doesn't exist now?
Old Aug 2, 2005 | 01:55 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
i'm in the middle of switching to a carb. so far i have a rpm performer intake on it, and i have all the emissions crap off. i have an hei distributor and a quadra jet.
Old Aug 2, 2005 | 07:50 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Buy an MSD box and Pro Billet dist. Pt#8551. Plug the dist. right into the MSD and you're set.
Old Aug 7, 2005 | 10:19 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
I just swapped from a 305 tbi to a carb. It was actually easier than I thought it would be. The msd box with a msd dist made everything easier. My hardest part was to make the electric fuel pump work. It was actually very easy.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
