does the carb control the fuel intake?
Old Aug 12, 2005 | 02:22 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
If i am running an electric pump to a regulator that feeds 5-6psi to the carb, will that flood the carb or does the carb control what it takes in? hope this question makes sense.
Old Aug 12, 2005 | 02:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
5-6 psi will be fine. Fuel flow into the carb is controlled by the floats and needle and seat. If there is too much pressure the needle will be forced off the seat and the bowl will overflow and flood.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
