missing on take off
Old Aug 13, 2005 | 09:06 PM
25TH ANNI RS's Avatar
Car: 92 camaro rs, 01cadillac sls,
Engine: 357ci
missing on take off
I finally built a decent motor and i'm having a few problems. I guess i will start of with my set up. It's a 357ci with flat top pistons. 64 cc tsc aluminium race heads, lt4 camshaft, accell dist, 750 edelbrock carbwith the small team g intake. the car was idling fine till you get on it then it pops out the exhust under a load fine in park. the car seems to be loading up when you take off in it then get better the more speed you pull. i have the spark plugs gaped at .045 is this too much for 10 to 1 compression. the car accelerates strong when the poping goes away. any help would be aprecciated thanks...
Old Aug 14, 2005 | 06:05 AM
contact's Avatar
Engine: sbc 350
the easiest thing would be wire the
secondaries closed , then do tests
with various accelerator pump settings.
You might try lighter metering-rod -piston springs.
Do the easy-cheap testing, first.
also try, lean the idle mixture, tell us what happens.
Is there any chance the ignition advance is
extremely wrong?
Old Aug 14, 2005 | 08:42 AM
Engine: 357ci
the base timing is set at 8* with the light springs in the distributor. i have 35* of total timing if this info helps.
Old Aug 15, 2005 | 04:21 AM
contact's Avatar
Engine: sbc 350
I suggest, first, eliminate overadvanced spark,
as a issue.
Try, for a test, reduce base advance, or put in
heavier distributor springs, and tell us what happens.
also, for a test, try removing the carb's
power piston springs. and tell us what happens.
that will put the metering rods into 'economy',
all the time.
If the carb is 'loading up', that needs to be fixed first.
Old Aug 15, 2005 | 10:49 PM
Engine: 357ci
thaks i'll try to get to it tommarrow if the weather holds out it's been crazy down here this year...
Old Aug 17, 2005 | 09:12 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Sounds like its going to rich on take of. It could be to rich metering rods or too big accelerator pump.
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
