holley external jet adjust......
Old Oct 17, 2005 | 10:31 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i was looking at the holley kit that allows you to adjust your jets from the outside.....anyone use this?
if so...is it a good idea or does it have its problems??
Old Oct 19, 2005 | 01:55 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
TTT....there has got to be atleast one holley lover out there that has tried this setup......
Old Oct 19, 2005 | 04:30 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
I had it on mine.. not a bad deal really.. you still end up dumping the fuel out of the bowls through the plug obviously.. but it is nice not to have to putt everything apart.. as long as you get the plugs back in tight you should not have a problem, but unless you are going to be doing jet swaps alot.. it reaslly is not needed and can potentially be one more part that can leak.. and leaks are bad.. lol
Old Oct 19, 2005 | 10:09 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you talking about the metering blocks with the adjustable needle valves for jets?
Old Oct 19, 2005 | 03:47 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah.... part number HLY-55001HOL on summitracing.com
Old Oct 19, 2005 | 09:24 PM
oh. i thought wrong then. Mine was jsut a fuel bowl replacement to swap out jets. without having to remove the fuel bowl (along with a bit of other stuff). I have seen what you are talking about though, never got my hands on one though...
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
86CamaroDan
Sep 29, 2015 10:08 PM
dusterbd
Sep 29, 2015 08:40 AM
