Holley Choke Adjustment
Old Oct 28, 2005 | 07:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Is the adjustment made by simply loosening the three screws and turning the choke cap? Or is it like the Q-jet: set the choke, open the thottle a bit, then adjust the butterfly until it's just touching or barely open?
JamesC
Carb was loading up so badly that I was forced to change the plugs.
Old Oct 28, 2005 | 01:14 PM
Damon's Avatar
Yeah, that's basically it. Make sure the vacuum hose to the little "kicker" is hooked up as well. There's a built-in vacuum servo in a Holley choke housing that's supposed to pop the choke open a little immediately after startup to keep from flooding the motor (sort of the equivalent to the little external vacuum canister on a QJet that serves the same function).
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
86CamaroDan
Sep 29, 2015 10:08 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
