difference between cc qjets
Old Oct 29, 2005 | 10:14 PM
flames82ta's Avatar
Transmission: th200 3 spd
Are all cc qjets the same between 82 to 86 f bodys? I know trucks were different cause they had no tps sensor. I have an 85 truck cc qjet and it has a different mixture plugin from my 82 ta. Is there this difference in f bodys?
Old Oct 29, 2005 | 10:58 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
flames82ta,
There were a few F-Bodies (very few) that had the 2-Point MCS System (easily identified by not having a rich stop). Most have the 4-Point system. The only real differences I've seen are in the Idle Speed Control Set-up. Other than that, to the best of my personal knowledge they're all the same carb.
Kurt
Old Oct 31, 2005 | 10:43 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Kurt is correct. All US-delivered 3rd gen V8's with carbs had the feedback q-jet carb, as opposed to some Canada-delivered versions that had the described truck-type carb with the 2 stage accelerator pump.
There were some minor differences in calibration between the computer command q-jets, such as main jets and secondary rods/hanger. Some LG4 q-jets also had a limit to the AV opening (easily modified to allow full opening).
69GTOby
Apr 18, 2016 02:34 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
