8psi 172 gph fuel pump
Old Nov 3, 2005 | 10:47 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Will i need to run a regulator with this pump if i'm using a 830 or 850 double pumper? Going on a race set-up 406, drag use only.
I guess i should also ask if this is enough pump for this motor?
Old Nov 4, 2005 | 11:06 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
That's plenty of fuel flow for your combo-I'm using a 95gpm with a HP spring if that gives you any comparison.
Personally i'd still intall a regulator, 1. future system expandability, and 2. if you get a voltage spike or something goofy it'll prevent the fuel from blowing out the vent tubes and possbily causing problems.
And for the record with all my engines and fuel pumps, have always set idle FP at 8.5-8.75psi. The little pumps WILL drop psi going down track so stepping it up ahead of time helps. Also even though you dont need sewer line for fuel lines, minimum I'd install is 1/2" or -8 that way it's done for future mods also. I personally run 5/8" or -10, but have always intended to feed the motor and the NOS solenoids off one fuel line from the tank.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
