Secondary,take a long time to open, do they open fast while driveing?
Old Nov 18, 2005 | 10:45 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
hi, if I take the air cleaner off and look at the carb I have to almost redline the motor before the secondarys start to open, is that normal? do they open faster when driving? thanks
Old Nov 18, 2005 | 10:54 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'm surprised they're opening at all when you do that.
Old Nov 18, 2005 | 07:23 PM
JBug's Avatar
Car: 86' T/A // 77 T/A
Engine: 86=305 Carb LG4:: 77= Olds 455
Transmission: 86=700R4 :: 77=TH350
I could be totally off on this, but its my understanding that while the car is in park or neutral, basically under no load, theres not enough vacuum generated in the manifold to open the secondaries....Thats how i understand it anyway. Please someone correct me if im wrong.
Put the rear up on stands, put it in drive and try it again.
Bug
Old Nov 18, 2005 | 09:36 PM
kal's Avatar
kal
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
It is actuall because there is too much vacuum in the manifold that holds them closed. When you slam the throttle down under a load the vacuum drops to 0 and the secondaries open. If there is no load the engine will rev up fast enough to keed a vacuum and hold the secondaries closed.
Old Nov 18, 2005 | 09:54 PM
JBug's Avatar
Ahh, thanks for clearing that up. I was looking at it backwards I guess. I'm trying my best to figure this stuff out
Bug
Old Nov 18, 2005 | 09:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Spring tension holds the secondary air valve closed, not vacuum.
Old Nov 18, 2005 | 10:01 PM
JBug's Avatar
The more I think of it yeah, that really makes alot more sense. Cause if you drive a car that is supercharged or whatnot and watch the gauge, when you step on it you see the needle come out of vacuum, past 0 and into boost. but when idlin or cruisin you're in the vacuum area.
Which poses another question, not one that really makes any difference, but on an NA car.. at WOT for example, you're out of vacuum in the manifold....is 0 the relative stopping measurement point? Or does it go on to create some minute measurement of boost? Sorry if this doesn't make any sense or is a stupid question. It sorta makes sense in my mind but don't know how to convey it properly.
Bug
Old Nov 18, 2005 | 10:04 PM
JBug's Avatar
Oh damn, well now i'm confused again lol
Old Nov 18, 2005 | 10:10 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That is true @ sustained WOT. Transition from part-throttle to full throttle is a different story. You have a vacuum brake that has a 2-3 second delay built into it that allows for a smooth transition. A performance version will be drilled to allow for a 1 second pull-off.
Old May 15, 2019 | 12:58 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Secondary,take a long time to open, do they open fast while driveing?
Old May 15, 2019 | 01:03 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
WTF?!? You dig up a 14 year old thread to post information that isn't even related to the post? Turn that infinite scroll off
Old May 15, 2019 | 02:35 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
lmao I total was responding to a different thread smh
I was wonder about that I hate that how it does that now
but thanks brother
Old May 15, 2019 | 04:49 PM
BLACK Z's Avatar
Car: 86 Z28
How do you turn that feature off?
Old May 15, 2019 | 08:45 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Go to UserCP --> Edit options --> then it is a bubble to change under "Display thread options" --> Then click "save changes" at the bottom
I didn't mean to sound like an a ss either, sorry, lol
Old May 16, 2019 | 10:26 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
lmao your good
when I look up past post I was like this one don't look familiar and seen your post
but your good I should of pay attention more but yea didn't know it was a option to turn off
Old May 16, 2019 | 10:33 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
I'm just curious to know if opie ever blew up his engine by revving it to redline while looking to see if the carb secondaries would open.
Old May 16, 2019 | 04:34 PM
BLACK Z's Avatar
Car: 86 Z28
Nope, I still have the car all these years later, It now runs a Nice Black coated 650 DP.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
