i dont know what to do
Old Nov 22, 2005 | 10:27 PM
i_luv_honda!'s Avatar
Car: 1983 camaro z28
Transmission: just got fixed~
ok my car is running fine except when i floor it the car just makes noise now and doesnt move liek it used to (different noise) and my exhaust is extremely rank, after liek 15 minutes int eh car u get a headache. (car sat for little under a year but started it monthly) i just want to know if anyone has any ideas on what might need to be fixed. i know my carb is a rochester q-jet but i dotn know if its CC or non-CC. thanks for any help
Old Nov 22, 2005 | 11:26 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Re: i dont know what to do
i_luv_honda!,
That's pretty scarry! I would immediately double-check the exhaust system and make sure your not getting some Co2 into the passenger compartment! From the description you gave there could be a number of things wrong but I'd make a thorough inspection of that exhaust system before driving it around again. The car has sat a while and you may need to rebuild/clean that carb. Let's identify the carb first then try to get some more info about how the car is running at idle, in gear, on the road, warm, cold, etc. That will help the guys around here get you started in the right direction. FIRST.... CHECK THAT EXHAUST SYSTEM.... maybe some critter decided to make a nest in there?
To identify your carb (see photo) a CCC-Q-Jet will have two connections one on the top for the MCS (Mixture control solenoid) and one on the front for the TPS (Throttle Position Sensor). Unless a previous owner changed it your '83 should have a CCC-Q-Jet (Computer-Command-Control)
Old Nov 23, 2005 | 07:53 AM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
if you smell rotten eggs , check your catalytic converter for flow stoppage. At least that is what it smells like to me..........good luck
Old Nov 23, 2005 | 09:56 PM
wow thanks i checked the exhaust and today when i started it it had a weird knocking, so i asked some friends they think the manifold where it connects to teh exhaust pipes sounds loose because it goes away after like 5-7 mins ( i guess the pipe heats up and expands). thanks for the helpful picture i need to go under the hood tomorrow and check. thanks for all teh help this site has been extremely helpful.
Old Dec 3, 2005 | 08:59 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
I dont know...Could be your screen name "i_luv_honda!"
Old Dec 4, 2005 | 09:51 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Hey, at least he has a third gen!
Old Dec 4, 2005 | 12:33 PM
you forgot the exclamation point. and everyone in the world knows honda means HORSEPOWER in swedish.... just joking. someoen always mentiosn the SN i really need to change it. just toi clear it up i dont luv hondas
