stalling when in gear?
Old Dec 11, 2005 | 04:53 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I have a 86 T/A with a LG4. I was told this car got a full tune up but they must have messed somthing up because. It will start right up and idle fine.When you goto put it into gear it stalls out. I manged to keep it running by revving it up a little.
any ideas?
Old Dec 11, 2005 | 05:00 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
vacuum problem?
Old Dec 11, 2005 | 05:10 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Axle/Gears: 3.42 posi
What does it idle at? Sounds like the idle screw needs to be adjusted but Im not familiar with the LG4 at all.
Old Dec 11, 2005 | 08:33 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Could be the idle air bleed valve. More info about your setup and the problem would help us help you.
GTAman
Jul 3, 2024 07:29 PM
IROCtometal
Sep 9, 2015 10:01 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
