fuel pump TBI to Carb.
Old Dec 13, 2005 | 06:17 PM
littlekings's Avatar
Car: Dirt Street Stock oval track 2bbl
Engine: 350 w/dart iron heads and 383 w/world products sportsman II heads
Transmission: saginaw
Can I hook mech fuel pump on same line that electric pump is on? Will it pull fuel or do I need to do the bypass style pressure regulator?
Old Dec 13, 2005 | 06:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you use a mechanical pump with a return line, you can use it and the in-tank electric will become a "pusher" pump.
If the mechanical doesn't have a return line, you need to put a return-style regulator between the mechanical pump and the carb. The electric will still be the "pusher" pump.
Either way, you need a return to the tank if you keep the in-tank electric pump.
Old Dec 13, 2005 | 06:59 PM
Even if I unhook the wires to the electric? Can the mech pump suck fuel out or will it suck air? I'm trying not to have to run the return line.
Old Dec 13, 2005 | 07:09 PM
five7kid's Avatar
Maybe, maybe not. Do you feel lucky? Most likely, it will be "not", then.
Either use the in-tank electric, or drop the tank and remove it. The "door #3" option is doing the job half-way.
The car already has a return line. Using it helps prevent vapor lock. In other words, it's a good thing. Why not use it? The in-tank pusher is about as 100% sure to prevent vapor lock as you can get in our cars. Pretty good insurance.
Old Dec 13, 2005 | 08:29 PM
Thank you, I was not aware that the return line was already there, all I'd need is the bypass regulator
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
evilstuie
Jan 9, 2020 08:29 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
