Posible carb problems...
Old Jan 11, 2006 | 07:16 AM
rtchaney's Avatar
Car: 89 RS
Transmission: Auto w/ evil shift kit; not my doin
Axle/Gears: It has a locker; not my doing
My car was running like crap(after firing, dieing and refusing to idle) So, i did the usual tune up, o2 sensor, dist cap, plugs wires rotor; same problem. Timing? Too rich? I havn't the slightest. Other info. Had new headers installed. I purchased the car with the smog pump removed. It sounds like it isn't firing correctly under load.
Old Jan 11, 2006 | 07:59 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
may sound stupid, but did you check your firing order?]
next I would check the float levels to make sure they weren't set to high.
Old Jan 13, 2006 | 06:07 AM
rtchaney's Avatar
Car: 89 RS
Yep... the firing order is fine. all plugs have a great seat. now, this may sound stupid; i've got a decent knowledge of any carb but the quad. is there an easyu way to check the float levles?
Old Jan 13, 2006 | 03:28 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
IMHO, it sounds like a timing issue. You have verified your firing order, but are you sure all plugs are firing? After you verify this, check your timing.
Old Jan 14, 2006 | 05:18 AM
Silver_Panther's Avatar
Car: 1982 Z28 & 1987 Z28
Engine: Carbed 400ci & TPI 305ci
Transmission: TH-200C & TH-700R4
Try running the carb a tad richer.
Old Jan 15, 2006 | 03:53 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
I just had a guy who supposedly owns his own shop do some work. I was busy and didnt have time. When I got home that night the check engine lite stays lit and the car runs like hell. The guy was going to adjust the carb, set the timing and install some vac lines. Havent had time to get back out and check out. Guy also is missing and has not called for his money. On the computer plug whick spot is ground and which is test.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
