jet size
Old Jan 30, 2006 | 10:00 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
jet size
i have a 355 882 heads 440 lift cam holley 650dp carb roller rockers performer rpm intake i need to know what jet sizes to start off with for the carb thanks.
Old Jan 30, 2006 | 10:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Start with what's in it.
Old Jan 31, 2006 | 12:36 AM
Car: 1987 iroc z
my brother had it on his truck with a 460 520lift cam and he had 75's or somthing in it and it was geting to much at idle. i just wanted to know what they came with or what would be good for it.
Old Jan 31, 2006 | 07:26 AM
five7kid's Avatar
The jets are in the main metering circuit, not the idle circuit. If it was getting too much fuel at idle (a common problem with universal application Holleys), the idle circuit needs to be adjusted, not the main metering jets.
Old Jan 31, 2006 | 07:33 AM
five7kid's Avatar
Let me answer this question.
Start at the sticky at the top of this page: https://www.thirdgen.org/techbb2/sho...hreadid=101977
Click on this link: "Holley Technical Information"
Which takes you to this link: http://www.holley.com/search.asp?que...Info%20FMCTech
Click on the "Tech Service" button in the left margin, which takes you to this page: http://www.holley.com/TechService/
Click on "Tech Library", which takes you to this page: http://www.holley.com/data/TechServi...%20Listing.pdf . From there you'll need to know the "list" number, located on the choke horn of your carb. Find it in the list, and it will tell you what jets and power valve it originally came with. You can use that as a starting point.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
