Fuel pump
Old Mar 11, 2006 | 06:55 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
Fuel pump
If I put a 750 Rochester on my 305 , would it be better with a mechanical fuel pump or an electrical one ?
Old Mar 11, 2006 | 11:36 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Either one would work just fine with that carb. Its really your preference. I personally pulled the electric pump out of my tank and put a mehcanical one on my engine just because replacing a mechanical one is much cheaper and alot easier. But if you like the electric then it should work just fine.
Old Mar 13, 2006 | 07:15 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
my 87 was originally an LG4 and has both an in tank electric pump, and a mechanical pump on the block. IIRC 87 was the only year an LG4 had an in tank...anywho...
I have had no problems using both. You should be fine too I would assume, coming from my experience.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
