vapor locking
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
vapor locking
I am getting vapor locking after driving a few miles. right now, i'm running rubber hose from the mechanical pump to carb. what have you guys done to stop the vapor locking? electric fuel pump? If so, what kind?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
An in-tank, or near in-tank pusher pump will help out that problem. The factory added an in-intank pump on carb models in 86.
Make sure you're routing lines as far away from heat sources as possible. Heat wrap around the lines helps can help as well.
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
