booster not flush in main body.
I recently bought a 750 speed demon. On the primary side one of the dogleg boosters are not pushed in flush in the carb. I called the demon tech line and talked to a guy on there, and he said that as long as it does not move or is loose its alright, and that it had to do with the swell when they put it in there and that it happens all the time. Im not so sure about that. It seems pressed in there alright. It looks like it needs to go in about an 1/8th of an inch. I was wondering if this will be a problem. It looks like it would because it is not positioned in the center of the venturi. Any help is appreciated.
Car: 2000 BMW M5
I don't think anyone on here can tell you something more relevant than what the Demon tech line told you. They told you why it happened and what to expect. What more do you want?
no green
Jan 9, 2016 09:22 PM
