Where does MAP sensor connect on CCC QJet
Old Mar 30, 2006 | 03:45 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have am retrofitting a 1983/1984 era emissions setup on a 305 roller motor in a 1983 Firebird. I have all of the vac lines for the carb and emissions system figured out using diagrams and the factory service manual, except for a couple things. The factory emissions diagram shows that the MAP sensor hooks up to a port on the rear of the carb. Unfortunately the diagram is an overhead shot, and the carb has 2 rear small ports -- 1 is on the base of the carb angled toward the pass side, 1 is on the airhorn up top in between the secondary butterflies. Which port is for the MAP sensor? What goes to the other port on a 1983? Thanks!
Old Mar 30, 2006 | 06:04 AM
The MAP goes to the one in the base, toward the pass side.
Nothing goes to the one on the air horn; plug it.
GTAman
Jul 3, 2024 07:29 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
