Can I take power brake booster line off center rear port of CCC Qjet?
Car: 2000 BMW M5
Hi guys, I have all of the vac lines hooked up for my v6 to CCC QJeted V8 in my 83 bird figured out. Can I used the large center rear port on the CCC Qjet to supply vac to the power brake booster (is this port on the carb manifold vacuum? It looks like it is). If not I have a plugged manifold vac port on the rear of the intake I can tee off of. I'd rather use the carb port as it will be neater this way. I found a 3/8" hose to inverted flare fitting that will let me interface directly with the fitting on the rear Qjet port, perfect for my brake booster hose.
Yes.
That's the factory location for that. There's supposed to be a fitting exactly like that, already there; somebody must have removed it.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
