regulator?
Old Apr 11, 2006 | 09:05 PM
xfactor200289's Avatar
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
regulator?
Ihave the mallory4309regulator/return style rated at 3-12psi,will this work on my carbed 350 with stock electric in tank pump rated 30-36psi
Old Apr 12, 2006 | 03:52 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yes. The stated 3-12 psi is the range of adjustability for the ouput pressure.
Old Apr 12, 2006 | 11:37 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
I used the same regulator on my holley and it worked awesome. I just put a pressure gauge on the output side near my carb to adjust to the correct pressure 7-9 psi.
Old Apr 12, 2006 | 08:41 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
thanks for the input,very helpful.
Mark_ZZ3
May 24, 2018 01:02 PM
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
Dragonsys
Sep 25, 2015 03:51 PM
