o2 tuning question
Old Apr 18, 2006 | 04:12 PM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
o2 tuning question
When reading the o2, should it be done in park or drive?
Also, to pass emissions, what should I be shooting for.I know 14.7 is the ideal A/F ratio (.6 mV I think). I'm using a one wire o2, right now in park i'm at .7/.8 at idle in park. I have less than 100 miles on the engine and have a part throttle miss i am trying to figure out. I was told I may have some rings that have not seated yet and causing a miss and that I should drive it more then try for tuning. Sound possible??? Ideas/info appreciated.
thanks.
Old Apr 19, 2006 | 01:37 PM
All I really want to know is if I should be checking under load.
Old Apr 21, 2006 | 01:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you want to check your mixture at part throttle, under load, then read your O2 reading at that moment in the car. reading it at idle will tell you your idle mixture, (obviously)
I don't think jetting or rings not seating would cause a miss. Usually igntion related...
Old Apr 22, 2006 | 03:47 AM
Well guess I have some more detective work to do.
Thanks.
Good luck on yours!!!
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
