carb adjustments...
Old May 25, 2006 | 08:32 PM
pats84iroc's Avatar
Car: 1984 iroc z28 1977 chevy short bed
Engine: 305 with a comp cam/ 350 built
Transmission: 700R4 with shift kit/ 4speed
Axle/Gears: idunno bout the car, 3.73posi
carb adjustments...
i just put a rebuilt Quadrajet on my 84 camaro, i ran the diagnostic on it and i got a code 44 which says: lean exhaust: how do i adjust the air/fuel mixture on it without taking it to a shop? the book wont tell me so i need your guys help. thanks
Old May 25, 2006 | 08:42 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Hello,
That search button up above is your best friend. If you learn how to use it it is invaluable. Good luck!
Old May 26, 2006 | 12:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You probably need a new O2 sensor.
Old Jun 1, 2006 | 08:18 PM
W72's Avatar
W72
Car: 89 GTA & 92 T/A covertible
Engine: 408LS-SC, 355 TPI
Transmission: 4L80e, 700r4
Axle/Gears: 12 bolt, 9 bolt
and I'd spend a few dollars replacing all the rubber and plastic vacuum lines. A vacuum leak misleads the MAF sensor and tells the ECM then it tells the MC solenoid to lean out the mixture.
Old Jun 3, 2006 | 06:49 PM
pats84iroc's Avatar
ok, ill do that, but when its cold, it floods out bigger than shi*, and it throws out as much black smoke as a freight train, could it be somethin else besides that also?
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
