St St St Stumble problems...
Old Jun 19, 2006 | 10:12 PM
mq1kael's Avatar
Car: 2004 Chevy 1500, 86 bird
Engine: 5.3, 69 327
Transmission: auto, th350
I'm having problems with a fresh build up. When I hammer the throttle, it usually dies. If I rev it up slowly, I seem to have no problems. This car isn't going to be a racer, or a daily driver, just a toy. But, this is a really annoying problem. Set up is as follows:
1967 327 ci motor, less than 50 miles on a fresh rebuild done by a local Machine shop
Camel Hump heads, I believe them to be the version from the 300hp motors... (any way to confirm that??)
Edelbrock Torker II intake, Carter 625cfm "Race" carburetor
HEI ignition system, plugs at .035
Th350
1986 Firebird, originally a 305/700r4
I know this isn't much to go on, but anyone know why it dies if I slam it but will rev up if I'm slow on the pedal? also cannot bring the idle down past 900, anyone have a baseline setting for the carb to help me out with?
Kael
Old Jun 24, 2006 | 09:43 AM
Vader's Avatar
Sounds like a non-functioning accelerator pump.
Old Jun 24, 2006 | 12:15 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
where's the timing at? what is the fuel pressure set at? are the floats set properly? how's the accelerator pump setup? does it squirt fuel at the slightest throttle movement? etc etc
Old Jun 30, 2006 | 01:25 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I never did like the carter carburators I had problems with them always going out of adjustments.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
