computer controlled ignition
Old Jul 26, 2006 | 09:15 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
If i just unplug my tbi and slap a carb on is it possible to keep the spark advance computer controlled. Will I run into any problems like a check engine light?
Old Jul 27, 2006 | 10:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, a 4-bbl carb won't fit well on a TBI intake manifold. I'd suggest at least putting on a carb intake manifold.
It has been speculated on this Board that you could put on an external throttle position sensor and as long as all of the other sensors are still in place, the ECM would continue to do its thing. However, that was with respect to replacing a computer controlled carb, and I don't know what all the TBI ECM expects from the TB itself.
Certainly the easiest route would be to do a non-computerized distributor. You'd have to make some alteration for torque converter clutch lock-up as well, but that's probably easier than the external TPS.
Here's one of the discussions of the external TPS (the later part of the thread) https://www.thirdgen.org/forums/carb...me-before.html .
pjsparts
Oct 29, 2025 06:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
