CARB HELP!!!!
Old Jul 29, 2006 | 12:05 PM
88-irocz's Avatar
CARB HELP!!!!
I NEED HELP I AM CONVERTING MY FUEL INJECTION TO CARB. I WAS WONDERING HOW I SHOULD CHANGE MY FUEL PRESSURE. SHOULD I TAKE THE TPI FUEL LINES OUT AND PUT 1 FUEL LINE AND DROP IT INTO THE GAS TANK AND USE THE MANUAL FUEL PUMP, OR SHOULD I BLOCK THE RETURN FUEL LINE KEEP THE EXISTING ELECTRIC FUEL PUMP AND BUY A FUEL PRESSURE REGULATOR TO BRING THE FUEL PRESSURE DOWN TO 5 LBS. PLEASE HELP. I NEED THE CHEAPEST EASIEST WAY TO CHANGE THE FUEL PRESSURE.
THANKS,
BOB
Old Jul 29, 2006 | 06:38 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
do it either way. If I could do it all over again I would put a 1/2" new line all the way up to carb and put a real electric pump inline along the way. I would not depend on that stock electric pump for squat. Chances are it will fail.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
