bad studder problem
Car: 1989 camaro
bad studder problem
here's the low down when i hit the gas the car kind of leik dies then just all the sudden comes back to life and roars. it happens everytime u kind if hit the gas real quick. if you ease into it it goes ok still does it a little but nto bad
the motor is a 383 with a holley 750 diaphram secondary on it. motor has dart pro 1 heads, with a edelbrock performer rpm intake.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sounds like a lean bog... probably your accelerator pump is out of adjustment.
I had a similar problem with mine. Make sure there is no slack at all in the accelerator pump cam arm. If you manually open the throttle, you should see gas come out of the shooter as soon as the throttle opens. There should be no delay. Also check the power valve. My 750 VS had a 6.5 in it. I installed a 8.5 and it helped out a lot. I still have a slight hesitation, and I suspect I could go to a 9.5 valve.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
what size shooter and accelerator cam you have in there?
Transmission: 4L80E/4L80E
What spring is in the secondary diaphragm?
Did somebody remove the check ball from the diaphragm housing? ( http://www.holley.com/data/TechServi...ech%20Info.pdf page 6)
