Carb Help
Carb Help
So i have a power valve question. Basically, i found out why my **** was running rich as hell during idle (cant believe I only thought about it after chp was having some article on it ). This is a mighty demon carb with annular boosters for starters. So their power valve is rated at 6.5" of HC...my **** idles around 4.5-5. Now the thing is, i don't just wanna fix it by changeing it out, id rather block it off and just play with jets. Now the thing is, on the secondary side of these carbs the power valves already blocked off. Jetting, out of the factory, is 80 on the primaries, 88 on the secondaries. Now if i blocked off the primary power valve, should I just raise those jets to say 88, or do I need to up the jetting on the secondary side as well?
Now here's the biggy...why
Thanks guys
-Rex
Thanks guys
-Rex
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
