Do you recall if there was a seal located in the passenger side footwell where the wire harness comes through the body and connects with the ECM? I've got a water leak located near there, and its only started since I pulled out the ecm and harness. It has been a while since I did it, so I can't recall if there was a seal somewhere. I thought there was a triangle shaped one that went around the harness where it passed through the body..
Kevin
Kevin
Yes there is/was a gromet in the pass side kick panel. Just take out the pass side inner fender. It is under the antenna mount.
