fuel to air mixture.
Old Oct 5, 2006 | 03:28 PM
ryanz53's Avatar
Car: 84 Camaro
Engine: 81 oldsmobile 307 5.0L
Transmission: 700r
Axle/Gears: 3.75
Hi guys.
Quick question.
How do I adjust my fuel to air mixture on simple 4 bbl rochester carb. (1984 camaro, non cc)
want to bring the oxygen up and fuel down.
thanx.
Old Oct 5, 2006 | 05:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Under what conditions - idle, cruise, power, WOT?
Old Oct 5, 2006 | 10:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
and then, why? Are you sure it's running rich?
Old Oct 6, 2006 | 12:29 PM
ryanz53's Avatar
Car: 84 Camaro
Transmission: 700r
Axle/Gears: 3.75
It is running rich all the time.
The guy I bought the engine had told me that he adjusted the carb to get more power, but it seams to me that he just cranked the fuel and dropped the gas.
I need to know whick adjuster is which on the carb.
thanx guys.
Old Oct 6, 2006 | 01:13 PM
five7kid's Avatar
The only adjustments are the idle speed, idle mixture, and choke (several choke adjustments).
The cruise and power mixture changes require changing the main jets and rods. You can also get different power piston springs. These all require removing the top from the carb to get to them.
The WOT mixture is controlled by rods and a hanger on the secondary air valve mechanism.
All of these assume the float is set and operating properly.
I doubt the previous owner did much to get more power, unless he really knows q-jets. Certainly nothing that would affect all phases of operation.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
