Running CCC QJet on hot 327. What mods to make?
Subscribe
Oct 21, 2006 | 11:12 PM
Hi guys, I am going to be transplanting the 327 from the 77 Camaro in my sig to the 83 Firebird. The Camaro will be getting a Dart headed 350 with my Holley Stealth Ram.
Anyhow, the 327 has a .462/.482 219/229 @0.05 110 LSA flat tappet cam.
I know on the old Qjets, you used a very long skinny drill bit to drill out the idle orifice restrictor, at the bottom of the brass tube pressed into each side of the casting behind the booster. I would also open up the idle discharge port size in the base plate. Do I make the same mods to the CCC carb so I can get the idle rich enough to be able to have adjustment using the IAB? I think I can get it to run fine, heck I had a TPI computer controlling this cam closed loop. It does idle choppy though.
Reply 0
Oct 22, 2006 | 10:43 AM
I wouldn't drill out anything in the CC-QJet before you try it out. I've used stock CC-QJets on much larger/bigger cammed engines than that. The computer actually runs them quite well, usually, since the carb is 80% self-compensating for changes in airflow anyway.
Just set the idle mixture screws out about 5 turns and do the rest of your idle tweaking (in closed loop!) with the IAB adjustment. There's actually quite a bit of adjustment range in that setup, believe it or not.
If you drill stuff out you're making permanent changes that the computer might not be able to compensate for.
Reply 0
Subscribe
