fuel pump question???
Old Nov 29, 2006 | 09:32 PM
fg_stadium's Avatar
I have a 88 2.8 camaro that I have a carbbed 350 in it,if I leave the intank fuel pump in it but disconnect it and use the block pump will fuel still flow throu the pump in the tank?
Old Nov 30, 2006 | 09:34 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Reports vary from "no problem" to "won't hardly run".
It's best to either have the in-tank running, or remove it.
Old Nov 30, 2006 | 07:00 PM
sLoW'n'StEaDy's Avatar
yeah, if your not using it, might as well remove it completely
Old Dec 1, 2006 | 10:12 PM
SaiyajinXero's Avatar
Car: 94 G20 hi-top conversion van
Engine: 350 TBI
Axle/Gears: something vanny
I have had specific experience with this, I have a mechanical pump for my carb and with my stock TBI in-tank pump, about 10-13psi it ran fine, but sometimes the carb would overflow and leak little puddles onto the manifold, with the pump unplugged but left in the tank the car did run, but stutters, if you floored it it would have a lot of trouble getting to high rpms, and dont even bother trying to drive, so yes the inoperative pump does hinder the fuel flow by a large margin. I tried again with a 45psi TPI pump (not using it FOR the carb, it was left over from a previous crossfire adventure) and it REALLY overflowed the carb before it could even start, and with no pump at all and a straight line with a sock on the end, it flows perfectly and runs great with no problems or overfueling.
Old Dec 5, 2006 | 06:39 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
do the job right. take it out of the tank and put a pickup in their.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
