Where is VSS located on 1983 Firebird? Under dash?
Old Dec 31, 2006 | 09:38 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I just took my 1983 Firebird V8 conversion project on its first trip ever, a 3 hr highway excursion. No problems at all except a check engine light that came on only occasionally. I get a code 24, VSS circuit low. I read that this code throws if the VSS reads less than 4 mph, and the engine is between 1400 and 4400 rpms, and TPS/load indicates > 4 mph operation, for more than 20 seconds.
This car is a mechanical cable speedo. The speedo works. Is the VSS one of those things they call a speed buffer on this car? Is it located up behind the speedometer in the dash cluster?
The check engine light clears every time you restart the car, and comes on about 20 minutes of highway driving later. If the VSS output was zero mph wouldn't the code throw a lot faster, or does the computer only run the VSS check periodically?
Old Dec 31, 2006 | 11:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't know about the "speed buffer" part, but the VSS is attached to the back of the speedometer.
Old Dec 31, 2006 | 11:43 PM
Car: 2000 BMW M5
Thanks, I'll have to check the wiring. Is there any way to check a VSS without hooking it up to a scope?
colton_carlson
Mar 8, 2019 12:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Pilotrick50
Sep 2, 2015 12:48 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
