progress on the carb swap
Old Jan 3, 2007 | 07:00 AM
89irocTPI's Avatar
So far i have bought holley street dominator high rise intake, summit hei dist, mallory 3 port regulator, all the fittings and lines, 14x3 air cleaner, all the gaskets and bolts, water neck w/ thermostat. Im trying to piece together what i need. I still need i think a carb throttle cable, carb tv cable, carb (going with a 670 street avenger) throttle bracket for the tv cable, carb gaskets, carb studs, fuel rail, what else on the carb itself do i need? Also can i reuse my stock upper radiator hose?
Old Jan 3, 2007 | 09:12 AM
ohiothirdgen's Avatar
You can use stock hoses and such. Id suggest going with a regular holley over a street avenger. The street avenger series seems to be a pain ( at leats thats my experiance with them). If you go that route good luck with it I hope you dont have trouble. The intake is the same intake Im running. It does pretty well. Is your aircleaner a drop base? You will probably run into clearance issues with a stock hood. I have a cervini cowl so it was a nice fit for me.
Old Jan 3, 2007 | 06:32 PM
89irocTPI's Avatar
i dont understand how the throttle cable hooks up to the carb and how to install the return spring and what the tv cable clips to on the carb.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
