Using cross fire intake for 2x4 carbs
Old Feb 6, 2007 | 09:13 PM
SVOwagon's Avatar
Does anyone know of anyone that has done this or knows of any pics of a cross fire intake that was used to run dual fours? I got a lower intake without the top for dirt cheap and was thinking of making a top plate for it. I know that the intake will flow like crap, but I'm not looking for performance here, just for looks. Thanks
Old Feb 7, 2007 | 12:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It will work, I almost did the same thing a few years back. That manifold is based on the '68-69 Z28 crossram, which did use two Holleys. Just have to make a top plate and linkage that will work between the two carbs. The way GM had it setup on the '68-69 version was to have the rear carb facing forward and the front carb facing backwards, and IIRC the secondary linkage (DP carbs) on the rear carb was hooked up to the throttle linkage on the front carb.
Good luck, and get pics!
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
