carb questions
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
carb questions
after looking through the message boards here and elsewhere, i have noticed that many people complain about the street avenger carbs. i was planning on upgrading my carb and buying a street avenger. i think my stock qjet is a 600cfm carb, should i stick with a 600 cfm carb or go bigger or smaller. i have a performer intake. my engine is a L69. also, what other carbs should i consider?
Car: 1987 TA
Engine: 350 stock/twecked
Demon carbs are great
also a larger carb tunned to the smaller motor will make more power if the car is for drag only (beware lots of knoledge need for carb tunning with this method)
later
and
GB
rk
later
and
GB
rk
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Stick with your stock carb until you can explain with some authority why it's inadequate to your needs?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Quadrajet carburetors are EXTREMELY tunable... why would you want to ditch it? Are you afraid of the computer feedback for the mixture control? You have a lot of potential in your carb now; no need to spend money. Now is the perfect time to buy a Quadrajet manual and start learning.
If you need to drive your car everyday while you're experimenting then get another one at the wrecking yard and play with it while you are driving your car now...
Just some well-intentioned advice...
84z96L31vortec
Aug 20, 2017 12:16 AM
