E85 Update: Plugs after a hard season
Old Mar 14, 2007 | 10:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There was a lot of discussion about E85 last year. I decided to give it a try, and ended up season champ in my class . (Not related, I'm sure. )
Anyway, here's a couple of pics of the plugs. I actually richened up a little for sea level in Topeka for the Div 5 finals in September, and didn't put it back for one last race day in October. So, they're a little dirtier than they would be otherwise.
The plugs aren't in firing order, the one on the far left was from #5, I believe, the cylinder with a smashed down header tube (hoping to fix this spring). The 2nd photo is turned 60 degrees from the first photo, same plug left to right, respectively.
I didn't keep close track of total runs, but it must have been somewhere between 150-200, plus driving to the track and a few other pleasure trips.
Attached Thumbnails E85 Update: Plugs after a hard season-plugs-after-2006-season.jpg   E85 Update: Plugs after a hard season-plugs-after-2006-season
Old Mar 15, 2007 | 10:14 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Cleanest plugs I've seen after good use
Cornholio7979
Sep 20, 2018 02:31 AM
gixxer92
Sep 1, 2015 04:32 PM
db057
Aug 22, 2015 08:17 PM
apie2546
Aug 8, 2015 07:12 AM
