Fuel pump relay?
Old Apr 8, 2007 | 07:58 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Fuel pump relay?
I wanted to know if i need to modify the fuel pump wiring in my TBI to carb swap. I tried to run it tonight and after probably 1-2 minutes the car died off as though it was out of fuel. Then i flipped the key on and cycled it a couple of times it, then it ran again, but only for maybe 15 seconds until it died again, i had just put fuel in it, so im sure its not out of fuel. I was wanting to know if i had to run a jumper to the fuel pump relay? im going to try making the pump run by using the diagnostic port tommorow, but i don't think that would suit me as a permanent fix.
Old Apr 8, 2007 | 10:30 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Fuel pump relay?
Run the green/white wire from the relay, through the firewall, to a keyed on 12v source on the fuse box (on my TPI swap, I took out the two 'injector' fuses since they were no longer needed, and plugged the wire from the relay into one of the terminals.) You should have a slot somewhere you can work with. Now, when you turn the key, the pump will always run.
Old May 5, 2007 | 02:23 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
where are the two injector fuses?
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
