Secondary AV Spring on quadrajet.
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Hi,Does anyone know where i can get a spring for the secondary av tension.I took my carb off to do some further checking on my current problems,and found the spring to be completly distorted.Is it available in any rebuild kits?.I know that the av is held shut by the choke pulloff,is the spring needed as well?,and will it cause any driveability problems to run without it?.
Thanks,
Alicat.
Thanks,
Alicat.
Transmission: 4L80E/4L80E
It doesn't come in any kit that I've seen.
It's best to have the proper spring.
Try giving these guys a call http://www.carburetion.com/quadrajet.asp 1-800-994-2272. They don't list it that I've seen, but they've got more parts than they list.
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Re: Secondary AV Spring on quadrajet.
Well, I have my A/V spring pretty much at "0" tension in fact when I shut the engine off the A/V's slowly open. When I start the engine the choke pull-off closes them. I also think that choke pull-off's have differant open/close rates so a lot would depend on thoes rates. Anyhow works for me.
Auggie
Auggie
MrPackstin
Oct 25, 2017 08:09 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Dragonsys
Sep 25, 2015 03:51 PM
