Edlebrock Loading up
Old May 20, 2007 | 10:21 PM
183berlinetta's Avatar
well i finally got my 83 running. its doing ok except after the car gets to a good operating temp. it seems to be loading up with fuel. it hesitates and 'stalls' a little when i initally throttle it to take off, but only when i just take off. after im going it does fine. but initial throttle response is terrible. i dont know if its the timing. (which is set at 12 degrees advance with a .468 cam)
the metering rods, the floats, or if the carb is out of adjustment.
some advice/help please.
and no remarks from you holley guys just because its an edlebrock. lol.
Old May 20, 2007 | 11:36 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Edlebrock Loading up
Did you try adjusting the accelerator pump arm? There's three different holes on the pump arm, try reloacting the rod to one of the other two and see if performance changes.
_Clark
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
jrdturbo
Mar 31, 2016 02:58 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
efiguy
Sep 27, 2015 01:30 PM
