Vaper Lock
Old Jun 8, 2007 | 05:55 PM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
Vaper Lock
Just replaced the 305 with another 305. Having a problem when hopping on the gas it is bogging down. Motor is stock no a/c yet and no emitions. It also is running alittle hot. Any ideas.
Rich
Old Jun 9, 2007 | 12:20 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: Vaper Lock
Running alittle hot is probably the cause...my car was running about 220 the other day because it was so hot that day and I experienced vapor lock myself, my car would almost die then take of for just a split second and amost die again, I had to be real easy on the gas just to get home. I dont have any problems when it is cool outside 70's or low 80's but the other day it was above 90 and I had that problem. I would start with trying to make your car run cooler...what temp is it running at? What intake and carb are you running? Aluminum intakes dissipate heat alot better than a cast iron intake. Either way I would get your cooling system right and then go from there.
Old Jun 9, 2007 | 01:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Vaper Lock
Doesn't sound anything like vapor lock to me.
Old Jun 9, 2007 | 08:19 AM
OS3Fleming's Avatar
Engine: 357 SBC
Re: Vaper Lock
It has been running 220. The thermo they out in it is 195. When I get it back from the shop should I change it to 160 or 180. Would that make a difference. I am running a Qjet 4 bbl. It is electronic stock carb. STill have the fuel metering sensor, and another sensor( forgot what it was).
Old Jun 9, 2007 | 12:34 PM
OS3Fleming's Avatar
Engine: 357 SBC
Re: Vaper Lock
Its not vapor locked, the back 2 bbls are not working. YEA THATS GREAT. So I will have another thread in a second. With pics and the question I poss.
Rich
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
