computer controlled to non computer controlled
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i have an 84 camaro 305 engine. we replaced the computer controlled quadrajet carb with a non computer controlled quadrajet. when i mash the pedal the car itself wants to die out. am i getting to much gas? or is it something else? it has stock hei not sure if need a vaccum advanced one or not. its an 800cfm carb we put on. any help is appreciated. bill
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: computer controlled to non computer controlled
You need a distributor with centrifugal and vacuum advance.
Transmission: 4L80E/4L80E
Engine: 355
so that will cure my problem then? whats centrifugal and vaccum advance? where can i get one at?
Engine: 383 Carb
Transmission: 4L60
It might not entirely cure the problem, but it's sufficiently wrong that there's no point trying to do anything with the car until its fixed.
In the factory setup, the ECM varies the timing for different operating conditions based on the information from various sensors. You've eliminated the sensors on the carb, so the ECM can't control the timing anymore.
A distributor from an older non-computer controlled vehicle would be a start, or there are numerous aftermarket ones available.
Engine: 355
Engine: 383 Carb
Transmission: 4L60
Yes, the non-computer controlled distributor has a weight and spring mechanism to advance the timing as engine speed increases ("mechanical" or "centrifugal" advance), and a vacuum pot to advance the timing as engine load decreases ("vacuum" advance).
Engine: 355
thanks for clearing that up.. by chance no any places that sell em cheap? summit has sum but dont know which to get
Engine: 355
ok i found a dist cheapest is 240! can u make a stock hei distributor vaccum advanced? like i took computer off carb, would that dist running the sensors on carb be able to be made to work?
camaro1185
Oct 26, 2015 06:51 AM
Doobie52
Sep 11, 2015 06:19 PM
