Still Having carb Problems....
Old Jun 17, 2007 | 12:04 PM
acerocks666's Avatar
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
Well I still can't get my car running right. I am having probelms with it not holding an idle and when I go WOT from a stop it does not want to go until about 15-20mph. I took the carb off yesterday and adjusted the av tension like it says to do in the sticky and I also put in a new fuel filter. I got the carb back on today and it still has probelms holing an initial idle. I got it going and was checking for leaks and stuff and I noticed that when I pulled the acclerator linkage it would barley shoot any fuel into the carb when it used to shoot a nice stream. I got the air cleaner back on and took it around the block and it seems like it is worse. It still does not wanna get up and go but now it seems like it is hesitating all the time. Plus the engine got really hot by the time I got it back home. I thought I might have put the fuel filter in wrong or something and when i pulled off my fuel inlet line it started shooting fuel all over. I did this for about a minute and finnaly stopped. I am almost about ready to just go buy a new carb cuase I am tired of messing with this q-jet but if I can do anything to save me 300 bucks I will. Any Thoughts......
Old Jun 18, 2007 | 05:12 PM
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
Re: Still Having carb Problems....
Well I messed with the car again today and ajusted the av tension again and it seems to be driving much better but I can still not get the instant power after a stop like I used to I think My choke may be sticking or something....
Old Jun 19, 2007 | 04:58 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Have you had the carb apart??
Auggie
Old Jun 19, 2007 | 09:27 PM
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
I have taken the carb off the car but I have not dissasembled the carb at all....
Old Jun 20, 2007 | 04:52 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Have you checked your timing? CCC-Qjet?
Before you undo your fuel inlet line, crack open the gas tank cap to vent the pressure.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
