Carb swap, what to do with computer?
Old Jul 23, 2007 | 02:42 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I'm just doing the finishing touches on my 91 formula. (info in sig) Can I scrap the computer and all the wiring, I saved a majority of it and stashed it away for now. I'm running a holley 650 dp w/ a converted points dizzy. I hardwired my fuel pump to the relay, it turns on when the key is on. So, can I get rid of the wiring and comp?
Old Jul 23, 2007 | 05:21 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: Carb swap, what to do with computer?
Take it out and sell it on here
In other words, you can take it out.
Old Jul 23, 2007 | 06:58 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
is it possible to leave the computer in there just so it can control tc look-up and the fuel pump?
Old Jul 23, 2007 | 09:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by 91 camaro racer
is it possible to leave the computer in there just so it can control tc look-up...
No.
... and the fuel pump?
Yes.
Old Jul 24, 2007 | 03:25 AM
ok so if i took the computer out, what would be the best way to control these things?
Old Jul 24, 2007 | 06:20 AM
five7kid's Avatar
TCC: 1) a kit from Summit, Jegs, TCI, etc., or; 2) a normally-open pressure switch on the 4th gear port in series with a vacuum switch, or; 3) a driver-activated toggle switch in series with a vacuum switch. In all of these cases, the power would still go through the brake switch - these other things just complete the path to ground. Details can be found on the Transmission forum.
Fuel pump: Wire a switched circuit through the oil pressure switch. For priming purposes (although not pure), a parallel power path to the starter solenoid. If you're clever, through the timed relay.
Old Jul 24, 2007 | 08:53 AM
Car: 91 Firebird
Engine: Turbo 355
I wired mine through the OPS. I have a manual so no TC for me. I was hoping to just scrap all the wiring and comp. What about my radio or fuse box or VATS? I don't have ac or heat.
Old Jul 24, 2007 | 01:12 PM
wow i didn't really understand any of that. is there a website that goes step by step with pictures? lol.
Old Jul 25, 2007 | 01:39 PM
five7kid's Avatar
The radio and fuse box are independent of the computer. There's a tech article about VATS linked from the thirdgen.org homepage that has all you need to know about it.
Old Jul 25, 2007 | 02:28 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
I used a toggle switch and a fuse for my fuel lpump and provided a new power line. I had to put to of the factory wires together on the rear part of the harness I used. Its been a couple of years and I belive there was a grey wire that was hot...I left my fuse box as all my lights and ACC work...
all the computer wiring harness where removed.
later
and
GB
rk
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
E Rod
Aug 28, 2015 05:17 AM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
