Does Oil Prssure Sender need to be hooked up to start LG4?
Old Aug 1, 2007 | 11:18 AM
taman86's Avatar
Car: '86 TA 305 F, '89 GTA 8
Engine: F 305 TPI, 8 350 TPI
Transmission: 700 r4
I just bought an '85 TA, that has an 305 Carbed LG4 in it, can't get it started, have spark, and engine does turn over, but won't run, even with stater fluid. I have noticed that there is no wire attached to the Oil Pressure sender.
On my other TA's, 305 and 350 TPI's the Oil Pressure Sender serves as a secondary way for the the fuel pump to energize, if the fuel pump relay fails, and the ECM detects Oil pressure, via the Oil Pressure sender.
Anyhow this is my first LG4 car, and I have'nt seen a Carb in 20 years.
Anybody know if my Oil Pressure Sender wire is necessarry for car to start?
Old Aug 1, 2007 | 11:58 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Does Oil Prssure Sender need to be hooked up to start LG4?
Your LG4 uses an old-school block-mounted mechanical fuel pump.
Old Aug 1, 2007 | 02:47 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
You are not getting ignition power. Test the voltage at your distributor on the portion that says "BATT" if that is good then your coil is shot.
Old Aug 1, 2007 | 03:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by taman86
... have spark...
Sounds like he thinks he has spark.
Old Aug 1, 2007 | 06:13 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Well you need Air, Fuel or Spark.
You think you have an electric pump, which is not the case so fuel is most likely not the problem Especialy since you used starter fluid. You have a carb, which is left relatively clean should supply the air.
Looks like spark is the only thing left.
My opinion still stands. I think you are not getting power to the distributor or your coil is bad.
It is possible that your distributor is jacked. Take the cap off the distributor and make sure the rotor is intact. Remove the rotor and make sure the rotor button is not smashed worn etc. Look under the cap itself and make sure the contacts are not arcing and sparking like crazy.
Orr89RocZ
Apr 25, 2016 08:28 AM
Navy8125
Aug 21, 2015 09:32 AM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
