quick question
Old Aug 29, 2007 | 06:15 PM
TorqueTilla's Avatar
Car: 1991 camaro rs
Engine: 305tbi with mods
Transmission: t-5
Axle/Gears: 3.08
quick question
real quick question guys, ive done my research but still got mixed reviews, my car came with the l69 dual snorkle setup and also a cowl induction hood. Should i sell my dualsnorkle setup and get an open element to put the cowl to use? or should i just keep the setup i have now?
Old Aug 29, 2007 | 08:32 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: quick question
if its all factory original , dont dare get rid of it . if you want to put a different air cleaner , thats your choice . check ebay now and see what they selling for . keep all ducting and hardware clean it , spray with oil and put it away in a box .
Old Aug 30, 2007 | 01:07 AM
Car: 1991 camaro rs
Transmission: t-5
Axle/Gears: 3.08
Re: quick question
well it came with my crate 305 so i guess its original?
Old Aug 30, 2007 | 01:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: quick question
No TBI's came with the L69 dual snorkle intake. That only came on the L69 carb engines, hence its name.
On a street car, I think the "ram-air" effect from the dual snorkel would work better than the "cowl-induction" effect at highway speeds. But I'm not an engineer.
Old Aug 30, 2007 | 05:51 AM
UNCLE TOM's Avatar
Re: quick question
thanks kevin , i dont think he is talking about the same snorkel as we are . seems a little confused . try search option , do more research .
Old Aug 30, 2007 | 10:06 AM
Car: 1991 camaro rs
Transmission: t-5
Axle/Gears: 3.08
Re: quick question
no, my car came to me with a 305 crate engine with the dual snorkle,it says right on it 305 h.o. , i guess the previous owner put it on, i do know wat i am talking about, sorry for the misunderstanding, the main question is, should i sell he intake and get an open element, because i think that would work with the cowl hood better than the dual snorkle
Old Aug 30, 2007 | 10:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: quick question
Keep it. I knew someone with a ZZ4 that ran mid 13's with the dual snorkel, so it flows enough for most mild street setups. Better then an open element sucking in hot air.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
