HELP, need Holley Advice
Old Sep 15, 2007 | 12:11 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
okay, on my 650 single line carb....which has an electric choke...i was doing a little cleaning and got up against the red plastic thing that makes the choke work....nothins broke it's just out of adjustment and the choke stays closed and doesnt move when u pull the throttle back....how can i fix this??????
ANY help is greatly appreciated
Old Sep 15, 2007 | 03:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: HELP, need Holley Advice
What you're talking about, I think, is the fast idle mechanism. It may have just fallen down too far to fix itself - its happened to me on my DP before. All I had to do was get a flat screwdriver under it, pull the throttle wide open (engine off) and pop it back up. It shouldn't take much force to do it. If it does, look elsewhere. Maybe you knocked the locking clip out of the choke blade rod when you were cleaning it, and its all out of alignment now.
Old Sep 17, 2007 | 12:07 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
i will look at that...but the only thing that gets me is the choke stays closed and u have to hold it open
Old Sep 17, 2007 | 03:36 PM
Air_Adam's Avatar
Electric choke or mechanical? Electric should have 12v going to it at all times when the engine is running.
Old Sep 17, 2007 | 09:02 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
its electric....i believe its just the fast idle got outta whack
Old Sep 18, 2007 | 04:47 PM
Air_Adam's Avatar
All you have to do to free it up if it did indeed just fall down too far and bind up, like mine has done, is (without the engine running) take off the air cleaner, hold the throttle open a bit to take any tension off the fast idle cam (thats the red things name), and with a long flat screwdriver, gently pry it upwards. It shouldn't take much force to pop it loose - if it does, theres another problem somewhere.
RedLeader289
May 28, 2019 01:47 PM
jaridjohn
Oct 5, 2015 07:01 AM
Royal_Z
Sep 30, 2015 08:45 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dusterbd
Sep 29, 2015 08:40 AM
