HI
Old Sep 19, 2007 | 05:22 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
HI
Im telling you im not gonna do a carburator swap but its more common than what im gonna do? i need pix of the front engine carburated lt1 (1993 -1997) what do you guys did to remove opitspark and what accessories bracket did you guys use to keep stock ac and p/s...me its gonna be a tpi car with a distrubitor in the back but no information at all about this....maybe carb people can help thanx!
Old Sep 20, 2007 | 12:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why an LT1 if you're going to use TPI?
Putting TPI on an LT1 engine just doesn't make any sense. Putting a carb on an LT1 engine barely makes any sense.
If you have an LT1 engine, use the LT1 induction system and ignition. You can use upgrade or aftermarket parts if you like, but don't mess with any other type of induction or ignition.
If this isn't an LT1 engine, why are you even talking about LT1?
Old Sep 20, 2007 | 03:17 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: HI
Have to admit, the LT1 heads....errrr top end all together is better than a TPI motor. So i see some legitimacy to it, if he found a cheap enough LT1. Well, they make a block off plate for the opti hole. Also your stock TPI belt drive would work if you could run a older WP, but you will just have to figgure somthing out.
Old Sep 20, 2007 | 07:59 AM
five7kid's Avatar
There is nothing about the TPI that makes it something to put on an LT1 engine.
Nothing.
Old Sep 20, 2007 | 01:20 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: HI
The fact remains, TPI on a stock LT1 motor will run better than on a TPI motor. I am thinking of using a TPI setup on my 95 camaro with a LT1 intake on a 383 small block. I cannot run a opti.
Old Sep 20, 2007 | 01:51 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: HI
Sure...
But you're still wasting your time and money putting TPI on an LT1. You're better off running a complete LT1 motor.
Old Sep 25, 2007 | 08:32 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
Re: HI
Why not just get the LT1 Intake thats modded for the distributor hole like people use when upgrading a TPI car?
