tpi fuel pump?
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
tpi fuel pump?
anyone use a stock tpi fuel pump in tank with a carb?
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: tpi fuel pump?
im running mine with the stock tbi fuel pump and a bg bypass regulator... working fine for the last year or so.
Engine: 383 LT1
Re: tpi fuel pump?
jegs sells it for 70bux part number 132-171021 i found mine new on ebay for 35... you just have to look around... i like it cause its a diaphragm bypass so it keeps pretty constant pressure. plus if it ever blows out its just a $20 rebuild kit that installs with 4 screws.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
