fuel pump question
Old Oct 15, 2007 | 07:22 AM
230 firebird's Avatar
Car: 1987 pontiac firebird
Engine: sbc 350
Transmission: TKO 600 5 speed
Axle/Gears: 323 posi/disc from 86 gta
fuel pump question
According to the tech article on switching from tbi to carb,i need to either get fuel pressure reducer or fuel pump from carb car.Can the fuel pump come from any early f-body with the ecm4 carb.Also,how do i hook up the eletric choke?
Old Oct 15, 2007 | 01:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, you can use an '82-'87 carb mechanical fuel pump. Be aware that you will need to either have the factory in-tank electric pump operating, or remove it.
Use a switched 12 volt source for the electric choke.
Old Oct 20, 2007 | 04:36 PM
Engine: sbc 350
Re: fuel pump question
Thanks for your reply
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
